Garys1969RR
I have a 65 Belvedere thats supposed to have a 451 in it. It is a 400 block, haven't measured the stroke. Eddy Perf RPM Heads, mild cam, stock rocker gear, 9.5 to 1 C/R. 4.30 posi in the rear. It's getting 210 to 220 PSI compression on all cylinders. But this thing won't even break the tires loose in 1st gear! No smoke, timing is right. I am now thinking maybe the timing chain is off 1 tooth. If the cam was advanced 1 tooth, that would account for the high compression pressures, and the strong exhaust pulse coming out of the ex pipe. As well as the low power output. Any ideas? I plan to pull the front cover saturday and check the cam timing. Something not right here.
My 451 in 69 RR also is getting 220 cranking pressure on all cylinders. It will fry the tires in 1st and 2nd gear. With 3.91 Posi. Runs mid 12 sec 1/4 mile.
