Sorry brother, gotta rip this apart...
and I think the A-999 was behind 360's if I'm remembering right (or A-994?).
This area is a little grey for me. FOR ME, all the transmissions are ether a 727 or a 904. While there are several subdivisions of the 904, there all 904's to me. The 999 has a low gear set, slightly different on the internals. More beef is what I would call it. I'm not up on auto transmissions since I like manuals andrun them. My auto trans cars are handled by a pro. Not me.
The 360's have a longer stroke & taller block than the 318/340 motors, so intake manifolds & pushrod length is different, but just about everything else is the same.
Longer stroke? YES! Taller block? WTF are you taking about?!?!?!?! The difference in a 360 vs 340 block is where the crank sits and the size of the cylinder bore. END! THATS IT! DONE! GOOD NIGHT ALICE!
This means, and I have so done these swaps over and over again it can be done with the flu and hung over while not being sure which end I should have over the toliet bowl!
INTAKES interchange on all "LA" engines except the early 273. 2bbl., 4bbl. 6 pack, aftermarket units, they all swap! The aftermarket makes a port size on these intakes that range from the smaller 273/318 to the larger 340/360 as well as an inbetween size designed to make a general use for all heads of the larger size window since the windows slightly change in sizes. The window is smaller on the intakes. (Weiands for example.)
PUSHRODS, when you are changing cams and valve trains and milling heads, block decks, should be checked for proper lengths. This also should be done with aftermarket lifters. While the stock length will propbably work across the board without any big issue, double check. Hyd. pushrods have a different length than mechanical cam pushrods. And a different length on roller cam engines.
I seem to recall the 340's have a larger exhaust (?) valve in '68-'70 than the other heads, fyi.
All small block heads come in like this on the valves.
273/318, small valve. 1.78/1.50 Later 4bbl. 318, 1.88/1.60 (360 headed)
340/ 2.02/1.60, late 1972-1973, 1.88 intake valve
360/ I have only seen 1.88/1.60 valves. I have been told and read the early 360 did/could receive a 2.02 intake.
FWIW!!!!!
A 318 can use a 2.02 in a stock bore.
360's can use a 2.05 intake valve in a stock bore.
Just had to get that out there as well. Just a "FWIW, FYI."
