what make and size was original for the spare tire for a 69 charger? Also will 235-60-15 in the front rub or do i have enough clearance to use, My friend says it won't rub but just checking with you guys also, Thanks
The spare size may have differed depending on the car/engine package. Hemi may have been a 15” whereas a base model would likely have been 14”. 205/75r14 or 215/70r14 would be fine for your spare.
A 235/60r15 will be fine on the front without rubbing if you have a “normal” offset wheel.
