68sportsatelliteragtop
Time for a new set of plugs and was thinking with todays gas I should go to a colder plug. I have been running Champion resistor 12 heat range. I run 92 or 93 octane and the motor is .030 over 10-1 comp. 383 with 484 purple cam and 750 vac sec Holley carb. I run the MSD 6AL with MP distrib. and a .045" plug gap. Timing is set at 32deg. w/vacuum advance plugged..The plugs looked a little lean, more white then brown. Anybody got any ideas about brand of plug and/or heat range.
