Spark plugs
Moparsmitty
5:07 PM
Washington USA
Just wondering what brand of plugs that you guys prefer for your Mopars, and why? I usually use Champions mostly out of habit. I usually only put a few thousand miles on a set of plug before I change them out since I'm not putting a lot of miles on the Belvedere anyway. Opinions?
Champions here. Have been changing them every spring for the past four years but this year decided to put $20 into a Summit plug cleaner and will try that instead.
Old school, Champion. GENIII, NGK.
Guess i didnt say why. I've used Champion in my dodges for the past 30 years largely because that was OEM. And I can assure you that I am NOT smarter then the engineers at Chrysler. Truth be known, I think spark plugs are pretty much the same if you stay with the major brands ( AC, Champion, Motorcraft, NGK...) and match your application. IMO
Ngk iridium. They can take a lot of abuse. Had an issue with a turbo charged 4 cylinder that puts down 450 HP at the wheels. It would destroy even platinum plugs. We found that iridiums are the only thing that will last.
:pimp3:i was told many many moons ago by a chrysler medicineman that they looooove champions . i've used them every since .
Champion plugs. My father has used them for the past 40 years in everything from a 55' chevy with a 327/375HP '30/30' duntov cammed engine out of a corvette to a 63' Dodge with a 4 speed-383 6-pack setup and a 'full race cam'! Don't really think spark plugs make too much of a difference, brand wise, but I always try and buy the premium series if available. Times have changed since then, and spark plugs have too in quality.
I haven't touched a Champion spark plug since 1990, and here's my "why" story. I was helping my roommate replace the timing chain on his Superbird in 1983, and being pretty young and stupid we decided to also do a tune-up while we were at the auto hobby shop at NAS Jacksonville.
We get the engine all back together, and do the tune-up, and we end up with a crank-no start situation. We thought we hadn't properly aligned the new chain and gears, so we took everything apart again and re-installed everything, and still we couldn't get the engine to start. We were scratching our heads when That Old Guy came over. That Old Guy is at every auto hobby shop at every military base in the World I think. He's some 50-70 year old dude that's worked on cars his whole life and knows about everything.
That Old Guy asked what the problem was and we told him. Then he asked what all we had done and we told him. Then all he asked was "Did you use Champion plugs?", which was the last thing we ever expected to hear him ask as we thought we had geeked up the timing. We said yes we had used Champions and he said to pull them out and never use Champion spark plugs again. We thought he was nuts, but we pulled the plugs and they were fine. We showed them to him, and he picked up each one and gave them a very slight bend and guess what? Four of the eight plugs had tiny hairline breaks in the insulators! They looked fine at first glance, but once you bent that insulator just a smidge, you could see they weren't. He said he saw that a lot with Champion plugs, and every time someone has a problem after a tune up in that shop, they've used Champion plugs. We went out and got a set of AC plugs, put them in, and the Bird fired up on the first crank.
Lesson learned? No. In 1990, I bought a set of Champions because they were on sale and put them in my 1987 Crown Victoria. The car ran like crap after I put the new plugs in, and I remembered what That Old Guy had told us. I pulled each plug out and checked it, and sure enough... two of the eight had cracks in the insulator and were misfiring. I put in a set of AC plugs and all was right with the World.
I haven't touched a Champion plug since, and only use Autolites in my Fords and AC Delcos in the Road Runner.
Been using Champions in my Mopars since 1972 when I got my first one. Mostly because they are OEM as mentioned earlier. You do need to be carefull when installing plugs , that you stay square with your tool on them , and dont overtighten them. Otherwise you will crack the insulators. I sold hundreds of thousands of Champion Spark Plugs over 30 yrs. Got very few back as defects, and that was usually due to user fault.
Don't like Champions, mostly because my dad has stories upon stories of how crappy they are. Figured no reason for me to waste money finding out on my own lol. I use NGK for anything foreign. Autolites, and AC delco for the domestic stuff.
Autolite.
Had a few cars with fouling issues. Using the same heat range Autolite vs the Champion fixed the problems.
I too have had a few issues with Champions in the past - stopped using 'em in the late eighties. I had a brand new set in my '64 and had an intermittant mis-fire, pulled my hair out trying to find the issue "assuming" the brand new Champions could not be the problem. Changed 'em out - problem went away...and I never looked back.
I knew that I would get differing opinions about this subject when I posted this question. It's all good. Thank you. I think that I will try a set of AC Delcos next time to see if I can tell any difference. One thing that I have learned over the years (the hard way) is that you have to be really careful installing plugs. Like 68Chicken says, it's real easy to crack the insulators without even knowing it and surprise, surprise, you have a mysterious miss with your fresh tune up.
