Did you get both sides of the bus? Seems to me that the power side only shows one fuse that you power the seats with for movement. Possibly another circuit for the heated seats. But one is a 30 amp and the other is a 20 amp fuse. Thats a hell of a load for an old harness unless you have some upgraded wiring.
Pardon my novice question (I am considering a similar swap) but I assumed you only needed 12v power, ground and switch (with appropriate breakers, wiring, etc) to use factory seats via the factory connector. Stated another way, find seats with both sides of plug, and supply power via wiring diagram to options you are using (is heat, cool, lumbar, recline....). Are you saying that you need the communication part of it too?
I don't want to use any computer modules.
Also....@dickdale what car are you putting them in? Do you you have any pics? I am concerned about the seat height in our older cars.I
Seat height is close, I am more comfortable leaned back a little so that frees up some headspace. If it is straight up, my head hits the headliner and I'm 5'11", But they look great and match the car perfectly. Dont mind the mess, I'm in the process of putting the rear challenger seats in.
Yes I did, and they quite a bit narrower than stock. I have the back rests mounted so I can still flip them down and still working on the lower seat mounts. I'll just make some filler pieces for the sides and call it done. It really does finish off the inside of the car having matching front and rear seatsDid you also replaced the back seat? I found the SRT's are pretty small in with.
