FOR SALE Stage VI standard port heads and intake. Offset intake rockers
8:08 AM
california
Hello everyone hi have a pair of new Stage VI standard port heads, a used Stage VI standard port intake and a set of new offset roller rockers (intake rockers only). The offset intake rockers are the only offset needed, the standard exhaust rockers work with Stage VI heads. I would like to get $2000 for everything.
A regular RB intake will not fit with these heads on an RB block without a spacer set. You would have to use the Stage VI intake or get a set of spacers from Ebay, because the ports are higher and farther apart. These heads can be used on a B block and an RB intake then fits. I am located in the Reno Nevada area, but can also deliver to Sacramento.
