Got a good one here and I need help.
My 1972 Satellite has a low mileage 360 magnum engine.
Edelbrock 600 carb, air gap intake, TTI headers, electronic ignition with super stock coil. The heads are stock other than bigger springs to handle the rumpity cam shaft. The 904 auto tranny has the stock torque converter with a cooler.
The vacuum advance is hooked up to part time vacuum port.
Timing is around 9 deg. BTC
Basically all components of this engine including electrical are new.
Plugs, cap, rotor, distributor, alt, wires, voltage reg.,......
2 belts. PS and ALT/WP.
The radiator is the only thing I haven't changed. It's the stock one used for automatic air conditioned car.
So here is the problem. When it's cold to warm it runs great with no problems.
Once I drive it around town in stop and go, it wants to stall at idle rpm of 850-900 rpm.
Things I have already checked:
The water temp is good with no boil over. I know it is because I have an electric fan with a thermostat that will cycle the fan on/off.
I have moved the fuel pump regulator and fuel line away from the engine. So it's not vapor lock.
I hooked up a vacuum gauge to check the vacuum and for leaks. No leaks found.
The carb is tuned properly, it's fresh gas..... I'm running out of ideas.
I'm wondering if the transmission could be the problem?
Does the characteristics of the fluid change causing more drag when hot?
What about electronics? Could the ignition module, coil or voltage regulator malfunction from the engine heat?
Could the radiator be plugged and not cooling enough even though it's not overheating?
Hopefully someone has some input or has had a problem like this.
Again it only stalls when warmed up...
Thanks!
Thanks!
