Standard roadrunner dash to rallye dash swap
Torkmnstr
7:21 AM
San Jose
hey guys, how hard is this...I want some better gauge options for my 69 roadrunner. Thanks.
The dash frame and the wiring harness are completely different. Pretty major job.
Anyone have additional input here? I'm thinking about doing the same. Just bought a 69 Coronet and my standard speedo is almost useless, the fuel gauge doesn't work and there is an aftermarket tach on the dash.
Does the wire harness require a total rebuild or just getting the wires into the correct plugs?
Some also overlook the fact that the windshield must also be removed.
Yes, major job.
From piecing info together here is what this entails
1. Install new rallye dash frame or cut your non-rallye to fit.
2. If installing a rallye dash frame, remove front window
3. Install the rallye wire harness.
4. Procuring rallye cluster.
5. seems like 90% of the dash pieces are slightly different so you also need to procure most of the rallye dash pieces. Radio bezel, lower pad, glove box.
Meh, I will stick with my sweep cluster.
