lvmymopar
I have a 66 coronet 440. When you first start the car when it is cold and hasnt been started for a few days the starter seems to be staying engaged. I turn the key off right away and then when you restart it it starts normally and then starts normally the rest of the time until it sits again. Is it the starter or could it be in the ignition switch? We replaced the starter about a year ago with a rebuilt starter. And I believe the ignition switch is original. Is there a way we can test the starter or ignition switch to see what the problem is? Thanks. It just started doing this and when it starts normally it cranks over really good.
