HT413
Semi Pro Bowler
This is a late year 440 out of a c body, I believe. Standard bore with OEM cast crank rotating assembly still in the motor. Oil pan is still installed and comes with motor.
Engine bores were coated with grease so is rust free and turns with ease. Bores look very good, though one or two have a small ridge. Drivers side front engine tab has been repaired by welding. Assume the block will need some machining and a good cleaning.
Pictures, casting numbers and ID pad to follow.
Asking $350. Will ship at owners expense, or will gladly meet someone a pretty fair distance. Located in northern New Jersey.
