Phantom440
Hi all,
I've got a couple quick questions.
My current steering column is a column shift auto, and I've got the three steering column collars necessary to convert it to a floor shift. I'm running into problems with the snap ring behind the turn signal switch... I've tried snap ring pliers, but the ends are too big for the holes... is this a Chrysler-only tool, to pull that out, or should I just find a smaller set of snap ring pliers?
Also, once I get the collars off, what do I need to pull out of the column that goes down to the base to change gears?
Thanks for any help.
