dpstark2
OK- so I converted my '67 Charger to a floor shift a while back. There is a '68 floor shift column up for sale here. I'm tired of my (column) gear shift flopping around and I have never found a '67 floor shift column for sale that I can afford. I know '67 and '68 are different (lower bearing, for example), but I don't care. If it works, it works.
My question for anyone who knows is will the '68 column fit? To compound the issue, the '68 looks to be for manual steering and I have power steering, so will the center shaft from my '67 interchange with the '68? The column mounts look the same, everything looks identical except the bottom end.
Thanks!
Thanks!
