Coronet6Pack
Hello,
On the 68 Coronet R/T we've replaced the stock worn out manual steering box with a quick ratio unit from Flaming River. When we went to rejoin the column to the gearbox with the universal joint we noticed severe binding. The cause is severe runout at the end of the steering column. It's spinning a circle nearly an inch out of alignment with the gearbox shaft. No wonder the other box was failing so quickly.
Question one...Could the column be rebuilt to repair the runout or is it more likely due to a bent column shaft?
Question two...I started calling this morning and spent several hours trying to hunt down a replacement column with no luck. I can find replacement aftermarket stuff from Flaming River or ididit (for a very pretty penny), but we want to replace it with a stock column.
Help...?
Help...?
