Vermont Rock
70 Road Runner. I want to remove the steering wheel. It has the thin wheel with a 1/2 horn rim. I've seen two versions & cannot confirm that my wheel is original. One version has a 3" (?) cushion in the middle. But mine has no cushion, just a small plastic Road Runner insert that is about 1 1/2". I'm sure that under the insert is the retaining nut, but I don't want to bugger-up the insert & would appreciate any help. It just doesn't look like there is enough room under the insert to allow a puller after the nut is removed.
The factory workshop manual does not give details on the removal of the wheel. Suggestions ? Thanks, Rocket
