step by step how to change a master cylinder?
scottlanes
1:52 PM
salem
Hi all, I'm going to have to change out the master and I havent done it before. Anyone got a link to a step by step kinda thing? Is there anything special I have to know?
thanks!
-scott
spray the lines down around the nuts with pb blaster. let soak a little while. take the line nuts loose. remove the 4 bolts and pull the master off. DO NOT MESS with the pushrod adjustment. that can be pita. get your new master and match it up to the old one. bench bleed the new master. install the new master. tighten the bolts up and then the lines. :headbang:
