63dodge440
iam looking for info, on how to replace my current stock tapered axle, with the setup that the backing plate will stay on the housing, so i can just pull the axles alittle to change the third member, the current stye you have to remove the brake line ,and the e brake to get the axle out, i know this swap has been done...dont care if i have to use the stock taper bearings, or goto the green type
