Hemibird
Hey folks, this one has me stumped.
The patient - 1970 Hemi Roadrunner
The symptoms - Will only start if I jump the solenoid on the firewall with a screwdriver. Fuses look "OK". Is the solenoid bad?
As always, there are a host of strange things that happened just before. The car stalled at a light. Couldn't restart. Replaced the balast resistor and just as she wanted to start, the starter stopped turning. If I trun the key, I get nothing. When I jump the solenoid (On the forewall) with the ignition on, Starts just fine.
Is the solenoid bad ... or the ignition switch? ... OR ... there is a "Fuseable Link" on the wiring harness. Does that have anything to do with it?
Thanks in advance
Thanks in advance
