streetlight trumps tennis ball
nothing gets past your goalie does it?
the light is only mounted in a temporary fashion using the factory access and mounting holes.
I didn't want drill new holes for the wiring and terminal block in the case until i saw how it worked, how it would look,
or even whether or not to keep it.
That's a cool over the top garage parking sensor, I like it... you get "2 thumbs up" from the peanut gallary...
well thanks to rusty I went out and swapped the leads for the red and green lights and swapped lenses so just picture it with the red at the top and all is good.
the yellow also acts as a nightlite. when you open the man door and just blow through to get something it will come on for only 3 min. then time out.
the green comes on for 5 min. when the overhead door opens or when motion crosses the threshold.
when the nose of a car crosses the red sensor it changes state on the relay and it kills the yellow and green, times out in 10 min. then the system resets.
