cylinder heads, port design, camshaft, even rotating mass, internal parts weights &
especially the valve springs & valve-train pieces, are a big limiting factor to RPM,
the durability issues, especially over 5500rpm &
especially in stock BB engines, stock OEM parts
especially if you don't buy really good forged rods
{racing aluminum rods or H-beam if steel pref.}
light-weight forged racing pistons, lightened crankshaft,
reduced counterweight radius to like 7"-7.125",
lighter the better in many ways,
allows for quicker acceleration & more durability,
less wear & tear, less rotating mass spinning around,
usually helps in results of less parts damage,
BUT only if you still stay with-in the parts ratings,
it's not smart to spin a big stroker crank too the moon, especially if,
you can get most of your power at a much lower RPM,
with good heads, valve-train, camshaft & ignition components,
that take advantage of the larger displacements & massive torque,
with-out spinning it to 8000rpm plus,
unless it's a full on "race engine" professionally built,
& built to do so...
my $0.02 cents
