DP78
So I noticed the other day on my 383 passenger side exhaust studs are leaking a little when the engine get warm. The ones leaking are in the middle and not sure if its one or two. The leak is not much and it does not leave a puddle or mess any where. Just a small enough leak to notice a trail down the side of the block. I have replacement studs, but not sure if I want to risk taking of the exhaust and breaking studs off. I do not want to get into a head removal process. I also really do not want to run some sort of radiator fix through my fresh record radiator. Just wanted to get some opinions from people on here. What are the long term effects of this and should I fix or just run it? Thanks and look forward to hearing some input.
