Stumped on Motor Mount; Looking for info
nm9stheham
12:20 PM
Waynesboro, VA
OK, I am stumped on this one. The subject is the passenger side motor mount for a 225 /6 in a '62 Dodge Dart. The applications all come up with the same wrong part with one stud on top which is this:
http://www.deaproducts.com/deaVideos/Dea360Viewer.html?picid=ZTJ46EDF&deano=A2303
The closest I have run across what looks like the mount that I actually have in my Dart is for a '64 A100 van, with 2 studs up top and one on bottom offset from center, and which looks like this:
http://www.deaproducts.com/deaVideos/Dea360Viewer.html?picid=VMOERV3G&deano=A2234
The motor mount bracket off the block has 2 stud holes, and the mount to the K member has one stud offset forward of the center line of the mount. This A100 mount is close but I have no dimesnion info to tell if it will actually fit.
So, I wanted to ask if anyone had any other old applications info that could help match this '62 Dart /6 passenger side mount up with another application so I can be sur eon the cross reference. Thanks for any help!
Just an update with some help from the slantsix.org forum: Looks like the 2234 is the right part for this /6 in the '62 Dart. I looked up /62 Plymouth Belvedere on a whim and it shows the 2234 part! Dumb applications info.....Case closed for now.
