Supplier for b body steering column main shaft?
koosh
4:32 AM
CT
If I decide to try this power steering box I have, and found used pump on Ebay , is there somewhere I can get just the steering main shaft? Am told I will need to change since manual steering has different length shaft?
I think you need to pull the whole steering column.
Check with @rick68b5 he has a 67 Charger he's parting out.
I believe you will need different pulleys as well.
So does this go on where ever I cut existing manual st6main shaft?, does it fit right onto factory power steering box?
Goes on the box,then you might have to trim the shaft to fit.
What color? From what car/year? Condition/pics? Trying to track down a P/S floor shift column for a 69 Road Runner. Thanks
it's from a 67 charger and its red power steering column shift
