The physical size difference between a stock chuck and the Borgeson is immediately evident.
The stock one is a beast.
The Borgeson looks to be almost 12 lbs lighter.
I decided to weigh the Borgeson with the stock idler and Pitman, hybrid coupler and hose adapters.
The Charger currently has a Firm Feel Stage 3 chuck with Fast Ratio Idler and PItman arms. Since the Fast Ratio arms are longer, they weigh more than stock arms so once I get them out of the car, I'll weigh the FF box and F/R arms to get an accurate number of the weight savings from this swap.
Regarding the Idler and Pitman arms....
I was pretty sure that I kept my stock ratio arms. I had them mixed in with Idlers and Pitmans from all the cars that I have parted out over the years. Most of the stuff I've done has been A body. I posted a thread here asking about the differences between A and B body steering arms. It must be a tough question because I didn't get many responses.
These are the small sector Pitman arms that I drug out of the shed:
All of them are in great condition but I couldn't remember which ones were for what chassis.
I put the car up on the lift and saw that the Fast Ratio Pitman had a banana curve like the Pitman arms on the right.
I don't understand the purpose of the curve. Maybe to clear the torsion bar socket and lower control arm?
Regardless....I think I found the correct Pitman arm.
For the Idler arm, I'm still figuring that out.
I've heard stories of the bad luck some have had with aftermarket steering gear in regards of quality control so I'd rather use a factory original part that is still in good shape or a "classic" replacement part that was made in the USA.
The Fast Ratio idler has a gentle drop to it.
