Sway Bar Front - Add 65 Satelllite - Non Factory
stanhope55
7:17 AM
Atlantic Canada
What kit/vendors are you all using for this. I need all the conversion hardware for the kframe and lower shock tower as my lower control arms are not factory for this. I assume I need to drill holes in kframe as well ?
Any install pictures would be awesome...
thx
i use a Firmfeel on my 65 coronet. came with everything. made a super difference in cornering.
The early B-body factory sway bar was a total bolt in piece. No tabs on the control arms needed. No holes to drill on the K frame to add one. Just a FYI post.
For those using Hellwig are you running discs up front with forward (facing front bumper) mounted calipers.... I heard there may be an issue with steering if forward mounted calipers ??
Well i got Drums, but there is not much room left.
Maybe an inch on each side.
Well I have ordered a classic industries kit for conversion to disc and it is apparently supplied by the right stuff company.62 - 74 b body kit.
I tried to find out from right stuff if the calipers are front or rear loaded but they were not sure... I found that very weird.
Does anyone have these brakes installed and can tell me if the calipers are front or back installed on the rotor.
