Tach light for 69 rr help please
rog_allen
2:52 AM
minnesota
Im missing the tach light with wire and the little horse shoe clip that holds it into the back with one little screw
anyone know were to locate one ? Factory indash tach
69 roadrunner
thanks
Year One has them. Try Herbs Parts also. They aren't very expensive.
You are right, I remember this now. I was able to use my old socket and wire and hooked it to the new dash harness. I still think I remember seeing one somewhere. Maybe it was on ebay? I will search around a little.
Check out chargerspecialties.com also. #CSe16 looks the same and is only $10.
thank you so much for your time !!!! we seen both of these but were not sure because they also have this one with three wires but is no longer available http://www.hardensmcw.com/ShowItem/102343 Tach Harness.aspx
we called charger specialties and its suposed to be the right one you gave
CSE16 cant thank you enogh !!! that was holding us up on putting the dash in thank you !! thank you !! thank you !!
