Looking to see if anyone can recommend an available pod that can easily fit a factory tachometer? I would like to affix to the steering column. I am not looking to swap into my cluster at this time. Thanks in advance!`
I already have the gauge and was wondering if there's a pod available. I could just add the tach and applicable gauges to my Satellite cluster, it's not that difficult, but I am seeing if there's an easier solution.
Could look at non working Tachs on eBay. I might have one or two since they aren't worth selling as is and I can't throw anything away, but I have no idea what you need without seeing it.
To put a factory tach in a 71-74 b body, you have to have the rallye guage cluster that has the temperature/fuel in one of the small guage pods,and alternator/oil pressure in the other small pod. If you have the rallye cluster with the fuel guage in the right side larger pod,that is where the tach goes so you cannot put the tach in that cluster.
