Tail light running lights are not working
hassyfoto
5:41 PM
Maryland
66 Charger
I replaced the turn signal unit and I have brake lights. Now I do not have "ANY" taillight running lights.
Both blinkers work and brake lights work. NO running lights just on the taillights. Running lights are working on the front of the car.
Auuuuuuugh !!!!!!
So far this is what I have completed;
replaced turn signal indicator unit ( new reproduction from Classic)
Cleaned the connectors from the steering column to the main wire harness
brake stop switch and connectors
all the connectors from the brake switch to the steering column to the driver's kick panel connector
Checked and replaced all the 1157 bulbs with new ones
Checked the high beam switch on the floor
Checked the wire harness and connectors at the back of the car.
I just replaced the light switch, again, today.
I need to get this fixed ASAP so the car can be driven.
Check connector in left kick panel, to see if you have power at connector and thru connector. Tail lights get power directly from headlight switch, does not go thru dimmer switch. If you have power at kick panel, check at left tail light.
yup, left kick panel connector would be next thing to check
