67 B-body
440 bored .030
3.75" stroke steel crank
Main stud girdle with ARP studs
Forged Domed pistons:
Compression Distance (in) 2.029 in.
Dome Height (in) 0.140 in.
Piston Head Volume (cc) -12.10cc
.040" compressed thickness Felpro head gasket
Scat H-Beam rods:
standard length full floating pins
MP .590" solid cam
Hughes EDM solid lifters "oil through technology"
Custom length solid pushrods
Victor Heads:
75cc chamber
2.20 intake 1.81 exhaust
Intake Runner Volume (cc) 280cc
Exhaust Runner Volume (cc) 100cc
Intake Port Location Raised
Exhaust Port Shape Rectangular
Exhaust Port Location Raised
1.6 ratio roller rockers
Edelbrock Victor intake Manifold
Holley 850cfm double pump
TTI headers 2" primary 3.5" outlet
Mallory ignition
Depending on what calculator I use, the CR should be between 12.5 to 13.5 :1.
Koffels speed shop told me they used the 590 MP cam in lots of builds with dynos around 570 hp using cast heads and lower compression. He said it should be well into the 600 HP range that I was wanting and LOTS of TQ!
Scat H-Beam rods:
MP .590" solid cam
Victor Heads:
75cc chamber
Mallory ignition
