Everything is working on my 67 RT restored dash with the exception of the temp gauge and I can't figure out why. I've installed the upgraded circuit board as well as new temp and fuel gauges and new temp sending unit. When I ground out the purple wire for the sending unit the gauge still does not move even though I'm getting 5 volts at the connector. I'm assuming that the temp gauge itself is not the issue since it is brand new but the needle wont budge. I would appreciate any input on how to get the factory gauge working before I give up and install an aftermarket mechanical gauge.
