mightymopar
Been having with my temp guage on my 67 Coronet 500, 318. I put in a new circuit board (not one taken out of another car) along with a voltage limiter in the dash. Turns out the original gauge was NG because the wire inside it was burned in half. I had a used speedometer panel out of a 69 Dart. The guages were the same except the way they were mounted. I fashioned it so it fit in the Coronet dash. It instantly burned up also. Is there something else I should be looking for as to the reason they torch themselves? The wire from the sender, also new, to the bulkhead conn. is good. Thanks, Dave
