CompSyn
themechanic already addressed the rear main seal with The Official Rear Main Seal replacement thread - LINK
In an effort to not hijack that thread as it relates to the rear main seal, I'd like to open up conversation with regard to all the other gasket and seal areas of the short-block B/RB motor in an attempt to have it all condensed in one thread. Soon, I'll be assembling my 383 so if possible I'd like to avoid as many potential leaks in the future.
So, what are your specific tricks and tips for sealing up the short-block? What products do you prefer as it relates to seals, gaskets, sealants, gasket makers, ect? Where do you apply sealant and where do you NOT apply it? Some of this info may be trivial to some but new info to others. Also, there may be more than one way to get the job done. I know you will all will be respectful of everyone's suggestions.
Areas of discussion:
1) Oil Pan and with Windage Tray
2) Timing Cover - gaskets and seal
3) Fuel Pump
4) Oil Pump
5) Distributor
6) Water Pump - Housing and Pump
7) Oil pressure tap (back of block)
8) Freeze plugs and Oil Galley plugs
9) Other?
Thanks in advance!
3) Fuel Pump
4) Oil Pump
5) Distributor
9) Other?
Thanks in advance!
