74RRGTX440
Any body have a thermoquad air door adjusting tool they would be willing to part with, or know of anyone making them? I need one pretty bad.
Years ago there was a guy on Moparts that said he was making them but after telling him that I wanted one, it never happened. What Mike said in his last post will work but the tool is easier.....been doing it his way for years.
No, that is accurate. Very.Doc Fiberglass Use to call him Doc Fibergas because he was usually full of it lol
Yes, Cornpicker's tool is just another one of his top notch tools from a top notch machinist. If Frank is offering, take him up on it! You won't be sorry.I made one for my buddy Dave who owns a carb shop in Youngstown Oh. He goes by Dana on "A" bodies only, ask him how it works. I might be coaksed into making a couple, what is it worth to ya ? Woodruff carb specialties
Me either, I have a big screw driver that fits the outer ring and a small one that I can squeeze in to hold the adjustment screw end while I loosen the ring, then adjust and retighten.Good grief. Adjusted TQ's a hundred times, never even thought about needing a special tool.
If you don't open the secondary's it not a problem.Chrysler build these carbs for years and basically failed to market the tool to the public to adjust the secondary door. Here in Denver the air pressure is lower, adjusting the secondaries from summer to winter or when traveling at lower elevations. We just need one in the trunk when traveling
