brasil
Hello folks...
just installed my "new " Thermoquad today.... First of all... Idles fine@ 14ish AFR... but crusing AFR is way to lean ( in my opinion)...@ 15.5-16.4 AFR If I accelerate HARD..my AFR goes to 12.8-13 ...
If I say "cruising" ..I mean I just keep the car rollin...coasting.... @ 40-50 mph.... not under load...
I change the main jet...was 0.098 and I went up to a 0.101 main jet.. the Rods are 2086( 0.069/ 0.061/0.040 ) but as I wrote...the carbs still runs a little lean ( in my opinion )
My Distributor ( MSD ) runs @ 15 ° BDTC at Idle and all in is@ 36 deg. at 3000 rpm...
My question is.. Does the carb run way to lean..?? What´s your opinion...? Should I go up with the jets ...??
The carb is a "leanburner" afaik... but there is a ported vacuum on the driver side of the carb ..?? The idle mixture screws are working perfect ( btw)
Thank you for opinions
Greetings Juergen
Greetings Juergen
