Throttle cable broke 70 383 RR
okiemopar
5:57 PM
Durant, Okla. South Central Okla.
My throttle cable broke on my RR, can you replace it with out taking the bracket out of the floor ? It is going to be a pain to get to the bolts on it so does any one have any advice on this? Thanks in Advance Ronnie
Yes it can be removed without taking off the throttle pedal. Interior side of the firewall where the throttle cable comes through, there is a retaining clip holding the throttle cable housing in place. You need to remove the retainer. At the throttle pedal bracket where the cable connects, you'll see a very small black plastic press pin adjacent to the ball swedge on the end of the throttle cable, remove that press pin and slide the ball swedge/throttle cable out of the throttle bracket. You should be able to pull the the housing/cable into the engine bay for removal at this point.
Good luck
