Tic toc tach
wrencher21
4:53 AM
annapolis,Maryland
Okay I accdently plugged the tach to the clock and the tach to the clock.the clock is fine but the tach is not working now has any body done this?
Never done that but...that means you would have put 12v to the tach. I can't imagine that's good.
Which wires? Did you hook the clock wire to post that's supposed to go to the wire up to the coil? The tach needs power, and runs off a blue wire to the fuse block... Maybe check your fuses.
No I hook it up to the wire connector because I made my tach harness it's been bad weather on the east coast so could not look at it again .
