miller
So, here's where I am. Looking for numbers I need to chose one.
64 Sport Fury, 440, 727 auto. Weight around 3400 lbs.
Tires-26"
Rear-8 3/4, 3.55 gears with sure-grip
Looking to run 93 octane, just a street car. What's this about fuel running hot these days?
Probably looking at a 650-700 cfm AFB, on the iron intake. Iron exhaust.
440 w/steel crank, KB237 +20 pistons, LY rods. 906 heads, and block has been decked .005.
Those pistons sit .003 down in the holes, with 5cc figured on the valve reliefs. Used 88cc to calculate the CR.
Figured with .045 head gaskets (in the gasket set I bought), but also punched numbers using a
.030 gasket. Why? I'm looking at .005 block decking, plus .005-.006 off the heads. Stock head gaskets (steel) about .021...right?
Adding .010 cuts, a .030 head gasket would keep all in order.
With a .045 gasket...CR=9.609:1
With a .030 gasket...CR=9.945:1
What cam numbers should I be looking for?
Thanks, guys!
Tires-26"
Thanks, guys!
