biginch=bigfun
I need a little help here. I've been trying to rid my car of a vibration that comes throught the floor. after a lot of work starting in the rear; wheels/ tires, axle bearings, drive shaft, freshly rebuilt trans, having the drive shaft rechecked for balance. I think I might have it pin pointed to the torq converter...
When I first put this combo together the entire engine was a 1978 440 and that is what stock converter I bought for the car. Then I had total cam failure which sent metal through everything. Rather than have the crank turned down & polished a friend gave me a good 1975 cast crank.
After diagnosing what i believe to be a balancing issue in the crank/converter area I went online to search out other stock converts. I found they offer a seperate convert for 73-76 that have two small weights out toward the ring gear and another for 77-79 that has the big "butterfly weight mounted inward near the flex plate mounts. The butterfly style is what I currently have. I'd like to know if I am on the right track because I have never messed with the cast crank 440s before & i dont want to drop the tranny & buy a different convert. on a hunch!
Ideas & insight wanted!!!
thanks in advance,
Louis
thanks in advance,
Louis
