Hey guys thanks for reading this thread and any help you provide. I am resurrecting my newly acquired basket case. Bubba was the last owner unfortunately and I have no history of the car but it was sitting for apparently 4-5 years now.
It has the stock 318 engine that I am working on but the trans linkage was disconnected for some unknown reason. The steering column was unbolted from the support bracket inside the car for some reason. The ignition lock was jammed and I replaced the the cylinder lock, bolted the column up and hooked the shifter linkage up to the trans but the rear wheels and driveshaft spin free in all gears as well as park. I verified that the drive shaft was connected to the tail shaft and moved the trans gear selector to all positions and the rear wheels move free.
Any idea on what else I can look at to determine the issue/cause? I am more of a 4spd guy and know little about the TQFLT or any auto trans for that matter......
Thanks again MF
Thanks again MF
