I am pretty sure that you will also need to remove the rear main bearing cap, to get to the seal retainer unbolted and out. And it seems that main cap torque is 100 ft lbs.
i just redid my rear main seal with the engine in, i did nto have to remove the rear main bearing cap on the seal holder, my car also has a tubular front end so no torsion bars or rack to interfere, which i think you might have to lift the engine slightly to get the pan off.
also i used the mancini billet cap with the o-rings and i highly recommend it.
also if your engine uses main studs and you use a aftermaket cap you have to notch it slightly as the dtuds hit and put the cap off centre which causes a leak
