It was very different as they came from the factory. It had a wider front drum that used 5 clutches instead of 4 with 15 springs in the clutch pack, a wider front band, 5.0 front band apply lever, 4 pinion planetarys both front & rear and different valve body calibration. However with aftermarket trans the components will be dependent on HP and application.
