Torsion Bars
RJB
1:42 AM
Wichita
Can someone explain the torsion bars to me, on my ford i could crank them up and down, on my 63 Dodge i cant find anywhere to raise or lower them, i need to lower them its like they all the way up. thanks
Under the lower control arm is a bolt, tighten it to raise, loosen to lower. Real simple when you see it.
thank you, i would of thought it would of been a little farther back
They're usually pretty hard to turn so make sure you soak them down with penetrating oil before you try to turn them!
