Torsion Bars
Coronet 14
6:26 PM
Hudson Florida
Well I finally got the torsion bar on left side out. The boot in the rear and the rear of the bar where it goes into the rear mount is packed full of grease. Is it supposed to be this way. When I start putting it back together, is there supposed to be grease on the end of the torsion bar when it goes into the plastic sleeve that's mounted into the rear crossmember?
Do new boots have the grease in them? If not do I just use wheel bearing grease? Thanks
Just put some grease on your finger, wipe it in the hex hole (both front and rear) and your good to go.
