Probably not as high as you would want it to, and not as strong either. TQ is not an area you want to try and save by being stupid cheap. My 2 cents. Now go put it in and let us know how high it stalls:eusa_angel:
Is the Poly converter a narrow or wide ring gear model? If it is a wide gear, and you have the correct input spline in your 727 to use this early converter, you can expect a flash stall speed of about 1800-2000rpm, if it is the narrow ring gear, then probably the 1600rpm range
