gottagettamopar
I just removed my PS Steering box to replace with a reman unit and I had to disconnect the two rubber trans lines that had been routed over the top of the steering box, along the inner fender and down to the lower radiator connections. Not an elegant solution.
I'm looking at making up some hard lines and running them along the bottom of the oil pan and up to the radiator.
What is the normal diameter tubing to use and what stops the lines twisting up if they're made up in hard line from the trans to the radiator?
Do I need to include anything in the shape of the line to take up movement?
Running hipo 383 and 727.
thanks
thanks
