Trouble getting brake fluid to rear drums
Mebsuta
5:42 PM
Khemi, Stygia
68 RR, manual brakes, 4 drums. Master cylinder is divided into Front and Rear, which go into distribution block.
Can't get brake fluid to the rear drums unless I open all four corners, and then it comes from the Front section of the master.
Right now, pedal is firm, I just have front brakes only. If I open up the back, starting with passenger side, that does not change.
Have you ever seen this before?
I was thinking there was a piston in the distribution block that had moved and blocked the rear half. I was trying to reset it by opening front bleeders at the wheels and stomping on it. That didn't work, so I opened all 4 corners. When I saw fluid in the the jars back there, I thought I had it until I realized it was coming from the front part of the master.
You need a master cylinder by the explanation you're giving. Take off the rear line from the master and see if any fluid comes out when you apply the brake,then take the cap off if it did and see which reservoir is getting low. Just don't stomp on the brake or that **** will be everywhere. This should tell you if it's the master or the proportioning valve. I think the front res. runs the rear.
If the MC checks out make sure the rear brake line and hose is not blocked.
the front of the master could be for the rear brakes...I'd fill the master,leave top off, open rear bleeders and wait to see if it will gravity feed/bleed first...if not, I would explore for blockage.
Usually when the rear flex hose is bad, it'll let high pressure pass but won't let it all bleed back and keeps the rear brakes dragging or nearly locked. Are the lines original? What all is new?
That's usually the way it is,front reservoir is for rear !
when ever I open any brake lines as a rule of thumb for myself - never let master cyl go dry but if it does or doesn't and I get no fluid to rear brakes I will always bleed the master cylinder first then open both bleeders for gravity bleeding when there seems to be a steady drip drip drip I close the bleeders and bleed rear brake cylinders always start from the farthest brake from the master cylinder. Good Luck !!
I also incuded a brake faq hope it might help as well !!
Brake Tech and FAQ
Pedal Ratio & Master Cylinder
Mounting the master cylinder to a frame rail or roll bar is recommended to ensure a solid mount. With the correct master cylinder in place, the pedal ratio must be great enough to produce 1200 psi system pressure under severe braking conditions. A pedal ratio versus line pressure calculator is available below. We recommend using a pressure gauge connected to the system to verify the maximum available pressure before running the car. If the desired pressure can not be easily attained the pedal ratio must be increased until the minimum pressure of 1000 psi is easily reached.
Master Cylinder Selection
A common problem in many applications is a spongy pedal. Brake systems inherently have slack in the system that must be taken up before work can be done by the pads. Slack comes from two factors: retracted pistons must be moved back out, and misalignment caused by deflection in the axle and housing mis-alignment. One of the most common misconceptions is that a larger master cylinder will create more pressure. While a larger master cylinder creates a larger displacement, it takes more force to create the same pressure as a smaller bore. While a larger master cylinder will take up system slack with less pedal stroke, it will take more force to create the same system pressure. The result after adding the larger master cylinder is a harder pedal which needs much more pedal pressure to create the same amount of braking force. For instance, moving from a 3/4" master cylinder to a 1" requires 77.7% more force on the push rod.
The goal then is to balance the entire system. Pedal force, system pressure and lever travel all need to be taken into account.
A balanced system includes the following things:
1) A lever that moves the entire stroke of the master cylinder
2) A Lever that moves comfortably in the confines of a car
3) Uses a reasonable amount of force to reach the desired system pressure
4) Is aligned well enough to minimize lever travel
Below is a calculator to help you find the correct ratios. First find the correct caliper combination from the chart, then find the correct ratio for your master cylinder size.
Caliper Combination: Area of Piston
(sq. in.) Reccomended Master Cylinder Size Master Cylinder Displacement (1.25" Stroke)
Two 83100 2-Piston Calipers
4.8 sq. in.
3/4" Bore
0.55 cubic in.
Two 81100/82100 4-Piston Calipers
9.6 sq. in.
7/8" Bore
0.75 cubic in.
Four 81100/82100 4-Piston Calipers
19.2 sq. in.
1-1/8" Bore
1.24 cubic in.
Two 81100/82100 4-Piston Calipers and two 83100 2-Piston Calipers
14.4 sq. in.
1" Bore
0.98 cubic in.
Two 81100/82100 4-Piston Calipers and two 73002 2-Piston Billet Calipers
13.7 sq. in.
1" Bore
0.98 cubic in.
Caliper Alignment Clearance and Position
Axle stand out controls the alignment of the brake system and as a result is extremely critical. To check stand out, first verify that the housing ends are square to the tube and axles. Install the axles and check axle standout (face of axle flange to face of housing end) as accurately as possible. See the chart below for stand out dimensions for MW brake kits. Stand out should be + .015 of the dimension listed. Shims are available to correct the alignment moving the disc outward .015” (MW catalog page 62 or online P/N 71009). Misalignment can cause caliper mount deflection which is one of the causes of a “spongy” pedal. Install your wheels to make sure the caliper to wheel clearance is adequate both radially and from outer face of the caliper to the inner face of the wheel. To bleed the system, the calipers must be positioned at 3 or 9 o’clock. This allows the bleeder to be highest point, ensuring that all air is removed from system.
Common Standouts
Symmetrical Ends - 2.834" Large Ford Ends 2.500"
Olds Ends - 2.834" Small Ford Ends 2.500"
Mopar Ends - 2.500" GM 10-12 bolt Ends - 2.812"
Proportioning (Pressure Reducing) Valve
The front brake kits with the integral hub and adaptor are designed for Drag Race applications. The main advantage is the reduction of weight compared to the stock braking system they are designed to replace. Several considerations must be taken into account when installing these kits. When any four piston caliper is used with drum brakes on the rear, a pressure reducing valve must be installed for front pressure control. Because of the small front tire contact area compared to the rear large slick contact area, the rear brakes must absorb more of the stopping energy than the front (contrary to a normal street car). A starting point would be 70% of the rear line pressure to the front brakes. This is especially important when using drum brakes on the rear. With discs on both the front and rear the percentage could be higher depending on the weight distribution and tire size but should still use the pressure reducing valve. We have a pressure reducing valve, P/N 260-2200, and we recommend its installation with front brakes. The pressure bias should be adjusted with gauges, MW P/N 81105, in the front and rear to confirm the pressure differential and then do a stop test. When doing a stop test, for a drag race car, the front tires should skid equally or slightly after the rear tires. This test can be simulated at a very low speed (approximately 5 mph) by using a wet surface or gravel and observing the lock up sequence.
Brake Lines and Fluid
Aircraft AN-3 brake lines and fittings are recommended. Only stainless steel braided teflon hose, stainless or seamless steel tubing (3/16” x .028”) should be used for brake lines. MW has available swaged Teflon Stainless flexible braided line that can be fabricated on a same day basis. The are available on line P/N 0300-X-X. Lines should be secured to chassis rails to resist vibration and routed in such a way to avoid possible contact with wheels, tires and other moving parts. Joining hard line and braided line or “T”s should be done using a bulkhead fitting and a small tab welded to the chassis. Long runs should be done with hard tubing to avoid expansion of flexible line. The amount of flexible braided hose in the system should be kept to a minimum. See page 63 or the online store for AN -3 fittings and brake line. Use of DOT 4 or 5.1 fluid with a high boiling point and lubrication for seals and pistons is recommended. Do not use (DOT 5) silicone fluids .
Troubleshooting Your Brakes
Spongy Pedal:
1) Air in system. Bleed brakes, making sure that the bleed valve is the highest point.
2) Disc warped (saucer shaped). Replace or surface rotors
3) Calipers not square with disc. Check housing end alignment, both concentricity and squareness.
4) Linings worn on taper. Make sure that caliper is centered over the rotor and the caliper bracket is not deflecting.
5) Master cylinder bore too small creating excessive high line pressure. Match master cylinder to system.
6) Master cylinder deflection. Stiffen master cylinder mounts
Brakes are locked up after run:
The piston in the master cylinder is not being allowed to return to the full retract location, when released. This condition will maintains line pressure and prevents the car from moving. Re-adjust the linkage so that the piston completely returns to the retract location.
Excessive pad wear, disc shows excess heat:
1) Lining too thin causing rapid heat transfer to calipers, boiling the fluid. Install new linings and re-bleed system.
2) Fluid contaminated with moisture causing boiling of fluid in caliper. Flush old fluid and replace with DOT 5.1 Fluid re-bleed system.
Maintenance:
Annual disassembly and cleaning of brake system recommended. Carefully inspect pistons and piston bores. Re-assemble with new “O” rings.
It was the rear hose. Took me a while because I generally work 7 days a week.
I think the hose is the original one because the metal end of the hose and the clip are fused to the bracket. I had to take the bracket off to remove the hose. It's all one piece after 45 years. I could probly spend a few hours and salvage the bracket with a dremel and a wire brush, but I ordered a new one from Mancini. I have a hose (Bendix 88224), but it's a little different from the original, and although it would probaby work, ordered another hose from Mancini too.
Maybe my old beater will be stopping better next time I get a block of time to work on it.
Thanks all.
