Trying to determine why the temp gage in my 66 seems to not be working. All new harness which I carefully went through and verified all wire indexing and continuity during replacement. Also I have an auxiliary mechanical temp gage under dash and it reads a pretty steady 180F when running.
I disconnected the harness terminal at the sender, hooked a wire lead to it, turned on the ignition, and momentarily grounded it. The gage responded immediately and went about half scale before I removed the wire from the ground. So I assume the gage is OK. Fuel gage works fine and I installed a new gage panel voltage regulator.
Then I hooked a multimeter to the harness terminal and grounded the other lead with the ignition on. The volt meter started cycling between about 6 or 7 volts and 0 volts similar to some time ago when I tested a dash instrument voltage regulator. Is the power to the sender unit fed from the low voltage side of the instrument panel regulator or should it have a steady 12 - 13 volts?
Checking the cold sending unit resistance between the terminal and ground/threaded housing shell, what kind of resistance should I be seeing with the engine temp around mid-60?
Anything else I could be missing or need to check? Hoping for a bad sender versus something more involved.
