TRW power steering pump
bodk
10:42 AM
Copenhagen
Hi Guys! I have hit ground hard during my restoration of my Coronet 1966 440 Convertible. The power steering pump was leaking thus I purchased a seal kit. I rebuild the pump with new bearings, shaft seal and O-ring. Then installed it. Didn't work! Took it apart did some studies on the Mymopar Service Manuals. Now it works poorly and with a lot of noise! It doesn't assist at all in idle. Then I decide to buy a new, but guess what. I can only find Saginaw pumps, NO TRW!
Does anyone know a place where I can purchase a TRW pump?
You can send it out to Steer and Gear they will fix yours
I just rebuilt mine did not run it yet those vanes inside have a specific direction also that valve inside must shuttle properly those snap rings on the shuttle valve tend to break I replaced mine one was broken they do not come in the kit also that one little piece always backs out that screws in that valve must be installed in its correct orientation I lock tighted mine so it would not back out these pumps were not great that is why Ma changed to the other units
