696969
I'm just going nuts here trying to trace the problem I'm having with my charging system.
Here are the facts:
1. I noticed that the Amp Meter on the dash was reading a low charge after the engine was running and lower when the various lights were used.
2. After testing the battery and alt and getting below 14v while running, in fact getting 11.5v, I decided to go ahead and replace the alt and (mechanical) regulator, thinking that the battery was not charging.
3. I put in a new alt. and reg. and no improvement. Alt is a 3 connector, just like the old one.
4. Put in a new Bosch battery
5. Popped off the + cable while running and the car dies.
6. Tried bypassing the ammeter on the dash and no improvement in voltages
7. Tested and found no resistance between the + battery cable and + post on the alt.
8. Checked the bulkhead connectors - all clean. No traces of melting. Cleaned bulkhead connector with contact cleaner.
9. Brought old alt in to be tested at Pep Boys and it charges correctly. Old alt is back in the car - returning new one as long as the old one works correctly.
10. Running out of ideas.
Note, I think the trouble started happening after I installed a car stereo amp (which I hook my ipod to) however, I cannot find any visible shorts behind the dash as a result of that install, nor can I understand how that would affect alt voltage in the car, which is back down to 11.5v
Nevertheless, I feel something is putting a load on the alt or the electrical system, but I can't locate it. Maybe the starter or relay?
Anyway I'd like to avoid having to take it to the shop. Any ideas anyone? :dontknow:
Here are the facts:
