Tubes or no Tubes?
wedge5
6:39 AM
Central IL
Just like it says. Should I run tubes or not. Strip car only(slicks)
Depends on you and your car. I run tubes and screws and not very much air and it works for me
Are the slicks better now so the air doesn't seep through the rubber anymore?
My Hoosier's I run without tubes and they hold air all year. The M/T slicks I had I used tubes as they would loose air real fast and I mean in 1/2 hr they would drop from 15 psi to 10 or less so it was tubes in the M/T's. Ron
No tubes! The only thing they're good for is adding additional weight! If they seep air like M/T is known for, just take a rag and wipe Dawn dish soap inside them on the sidewalls.
I guess it's personal preference. I've been doing this for forty years and have always run tubes.
They say no tubes might be a couple of hundredths quicker, and that is probably true. But, unless you are a class guy where every hundredth counts, I still like the tubes.
For me there is a safety question. I may be wrong, but I think that the tubes add just a bit of cushion.
My two cents.
